Author Topic: herreshoff 18'  (Read 1246634 times)
« Reply #150 on: March 07, 2010, 05:31:46 AM »
The Hull is in Great shape for a 36 year old girl the Swim Platform was optional
« Last Edit: October 15, 2011, 09:52:58 PM by Cardinal Joe »
« Reply #151 on: March 07, 2010, 05:36:46 AM »
The Farrow SystemŽ combines the fundamental elements of nature - water, heat, minerals, and air - and forges them into a powerful cleaning system. Patented worldwide, The Farrow SystemŽ can clean surfaces impossible to clean with other systems! "A natural combination"
The Farrow SystemŽ adds heat to a low pressure mixture of water and Farrow Green CleanŽ, a chemical-free, naturally occurring mineral. Adding heat adds energy, creating free flow in the system and allowing air pressures can be low and still clean efficiently. This heat also causes the Farrow Green CleanŽ crystals to align before leaving the turbo nozzle. This creates a controlled, highly efficient cleaning stream that resembles a stream of darts.
This safe, low pressure vapor-like stream is directed against the surface to be cleaned. Upon contact with the surface, each Farrow Green CleanŽ particle bursts into multiple cleaning "missiles" that lift the coating from the surface. Each particle packs many punches, reducing cleaning time and media consumption significantly. The process is dust-free and leaves only a moist residue which is easily swept up and removed. "Cleaning method comparison"
Farrow Green CleanŽ is available in several grit sizes specially developed for a range of cleaning applications. It can take off just one layer at a time and it can also create controlled profiles specific to your application.
« Reply #152 on: March 07, 2010, 05:46:32 AM »
cont...
« Last Edit: October 15, 2011, 09:57:59 PM by Cardinal Joe »
« Reply #153 on: March 07, 2010, 06:00:12 AM »
Adding a paint stand under the Pilot & Farrowing where the lift straps were holding up the Pilot ...
« Last Edit: October 15, 2011, 10:00:08 PM by Cardinal Joe »
« Reply #154 on: March 07, 2010, 06:10:42 AM »
Done for day , tomorrow is another day !
Found repair spot on the Swim platform ?....still need to fix the factory add-on swim platform Putty issues & start Barrior Coating the bottom etc.etc.....
Here's some pictures of the fiberglass work done today on the swim platform. All 1708 glass and vinylester resin....
« Last Edit: October 15, 2011, 10:04:12 PM by Cardinal Joe »
« Reply #155 on: March 12, 2010, 06:45:33 AM »
I want to take a POLL - Herreshoff Harbor Pilot bulk head wall ....
1) - keep the original look of the pilot bulk head wall ( no Window installation ) ?
OR
2) - Install  my old Classic looking Bronze Port Hole Window in the Pilot bulk head wall ?
 VOTE .... Original vs Port Hole ....  Thanks You !  Cardinal Joe
« Last Edit: March 16, 2010, 04:05:49 PM by Cardinal Joe »
« Reply #156 on: March 13, 2010, 12:11:22 AM »
Shoot me a Vote on my email ..... joec@cardinalyachts.com
« Last Edit: March 16, 2010, 04:04:22 PM by Cardinal Joe »
RBStuart
« Reply #157 on: March 14, 2010, 02:55:59 PM »
For my 2 cents' worth, I would go either way:  unadulterated as the designer(s) intended - or - an opening port would allow both through-cabin visibility (for the height challenged) & ventilation of the cabin.  In any event, any modifications MUST look professionally done & be in keeping with the character of the boat.  For what it's worth.
« Reply #158 on: March 15, 2010, 05:29:20 PM »
My .02 is probably not worth much but I have always felt that boats, cars, or widgets should be kept as "stock" as possible. There is usually good reason a designer designed it that way. If I must change something structural (IE I was really going to use the craft for some specific purpose and needed to add equipment) I would try my best to be able to return to original shape as easy as possible with as little structural change as possible.....
RBStuart
« Reply #159 on: March 15, 2010, 06:19:47 PM »
What is felt as the best trailer for the safe transport of a Harbor Pilot?  I'm anticipating one over the road retrieval (300 miles), then occasional launching(s), mostly for off season storage.
Bunks appear to offer the better hull support, while rollers appear to make the "on" and "off" easier.  Mostly, I want to be sure not to damage the hull in transport.  I appreciate your recommendations.
« Reply #160 on: March 15, 2010, 07:35:43 PM »
Bunks are far easier - easier on/off as well. Years of trailereing a similar Novi hull and I would never do anything but a float on bunk. Just MO....
RBStuart
« Reply #161 on: March 17, 2010, 03:52:02 PM »
Adam, I appreciate your response - can you be more specific?  I've spoken with a trailer dealer who favors rollers over bunks, but I've seen the stress that rollers can place on a hull.  That's something I want to avoid completely.  With respect to bunks, what would you suggest:  1 set, two sets, with or without rollers to support the keel?  Also, for the HHP, what weight limit?  Do you believe a single axle accommodating enough ?  Any insight would be most welcome.  Thanks in advance.
« Reply #162 on: March 17, 2010, 06:36:28 PM »
IMO - Rollers freeze. They need far more maintinence. They don't roll that well to begin with. Bunks support far more - and evenly. With a boat 18' which is fairly light they dont need anything more then bunks - single axle. In fact the hard part is keeping a boat on the bunks - the things are slippery (usually have a plastic covering on the boards which allows the boat to "slide" around).
RBStuart
« Reply #163 on: March 17, 2010, 10:50:39 PM »
Good Points - what about rollers for keel support?
« Reply #164 on: March 18, 2010, 02:10:06 AM »
unnecessary....
