Thanks HH,
One correction...according to the HMC built register, #1225 was built for Coakley in 1932 but for some reason delivery was apparently not made. As you suggest, Crusader may have lingered at HMC until Barden took her in 1938. I'm trying to get records from Barden Boat Yard.
Its interesting that Crusader also is the only FI23 with water-tight compartments for and aft. On Nov.2, 1932, Sidney conducted a flotation test, flooding the boat and measuring her trim. Sid noted the test on the 1225 construction plan. Differing from other FI23s, she also has genoa sheet winches on pedestals located aft of the cockpit, inboard of the coaming tails.
The construction plan also notes that in May 1939, HMC completed an order to install a 4Cyl Redwing "Meteor" engine. The engine was installed in a mahogany box in the cockpit. As I received the boat, the engine was missing and the remaining box was quite crude in construction. If HMC performed this work their quality control was lacking at the time. I'm installing a 48V electric drive which fits nicely under the cockpit sole, using the original shaftlog, shaft and strut.
Thanks again for the helpful response.
John
PS: Does anyone know who "Coakley" might be?
