Author Topic: Saving a Boston Whaler 13 from being a Flower pot !  (Read 235199 times)
Re: Saving a Boston Whaler 13 from being a Flower pot !
« Reply #30 on: March 22, 2010, 03:30:22 AM »
Starting sanding & patching ! Capt. Mike hard at work !
« Last Edit: November 29, 2012, 06:37:09 AM by Cardinal Joe »
« Reply #31 on: March 23, 2010, 04:54:07 PM »
Updated Pic's of the Farrow System Soda blasting Unit on HULL #221 !
« Last Edit: November 29, 2012, 06:37:30 AM by Cardinal Joe »
« Reply #32 on: March 25, 2010, 05:24:50 AM »
Barrier Paint Coat applied after the Farrow system ( Soda blasting ) .
« Last Edit: November 29, 2012, 06:37:59 AM by Cardinal Joe »
« Reply #33 on: March 26, 2010, 04:24:19 AM »
Awlgrip - the hull & then bottom paint !
« Last Edit: November 29, 2012, 06:38:18 AM by Cardinal Joe »
« Reply #34 on: March 27, 2010, 03:48:24 AM »
Farrow Systom (Soda Blasting) then barrier coated then taped,then sprayed awlgrip....then bottom paint..
Steps - 1,2,3,4
« Last Edit: November 29, 2012, 06:39:06 AM by Cardinal Joe »
« Reply #35 on: March 27, 2010, 03:56:58 AM »
Painted the deck in a light sky blue color ,pretty close color match !
« Last Edit: November 29, 2012, 06:39:38 AM by Cardinal Joe »
« Reply #36 on: March 28, 2010, 07:28:58 PM »
BW 13 - Hull # 221 ................
« Last Edit: November 29, 2012, 06:39:59 AM by Cardinal Joe »
« Reply #37 on: April 06, 2010, 10:10:59 PM »
More updated pic's ! " WOODY CLASSIC " we did a very nice refinsh job !
« Last Edit: November 29, 2012, 06:40:23 AM by Cardinal Joe »
« Reply #38 on: April 07, 2010, 02:38:07 PM »
Finsh Product ! Looks Dam Good
« Last Edit: November 29, 2012, 06:40:48 AM by Cardinal Joe »
« Reply #39 on: April 07, 2010, 03:12:35 PM »
Sure does!
« Reply #40 on: April 09, 2010, 05:03:42 AM »
This was my daughters 1985 Boston Whaler 13 - that I purchase new back in 1984 .....it was my first restoration years ago .....Paint color is flighting lady yellow before it was a hot color , this boat turned heads because of its painted hull ...... Cardinal Joe
« Last Edit: November 29, 2012, 06:41:28 AM by Cardinal Joe »
« Reply #41 on: April 09, 2010, 02:07:15 PM »
There is something about the 13' whaler....I don't see as many up here - deeper water I guess dosent make them as popular, but growing up on Great South Bay, next to a bicycle, this was the most popular mod of transportation before everyone could drive - and I be a close second at that. Certainly brings back memories...
« Reply #42 on: April 09, 2010, 06:52:34 PM »
Adam -the BW 13 were all over the bays in New Jersey when i was a young man .....
DIMENSIONS:
Length..13 feet 4 inches
Beam....5 feet 5 inches
Length/Beam Ratio...........2.5:1
Draft......6 inches (with engine tilted clear of water)
Weight..320 pounds Standard to 410 pounds SS Limited
Original hulls c.1959 weighed approximately 250 to 275 pounds
Maximum Horsepower..........40 HP
Minimum Horsepower.......... 9 HP
Capacity....................................6 Persons
Swamped Capacity................1,600 pounds
HISTORY:
Designer....................Dick Fisher, Ray Hunt, Bob Dougherty
First year offered..........1958
Last year offered...........Still available in the GLS model
Color..........................1958 - 1972 White Hull/ Blue Interior;
                                     1973 - 1993 Desert Tan
                                     1994 - 2000 White
                                     1998 - White Hull/Blue Interior on Limited Edition
M.S.R.P.....................$750 in 1970 for Standard Hull
MODELS AVAILABLE:
    RECREATIONAL
Standard ..........1958 - 1970 white hull, blue interior
("The Cox'n") mahogany thwart seats, white rub rail,  transom cut for 15-inch short shaft outboard motors
« Reply #43 on: April 10, 2010, 04:48:05 AM »
Another custom restore - 1964 Boston Whaler 13' ..... I purchase this BW 13 in Penna. it had been a fresh water boat .
« Last Edit: November 29, 2012, 06:42:02 AM by Cardinal Joe »
« Reply #44 on: April 10, 2010, 04:56:44 AM »
Engine: 1996 Mercury Force Tracker 40 HP W/Tilt & Trim Motor
« Last Edit: November 29, 2012, 06:42:46 AM by Cardinal Joe »
