Author Topic: Questions....  (Read 4713 times)
Questions....
« on: August 10, 2010, 04:15:16 PM »
1.  The Rig type column in the builders records seems next to worthless as J&M seems to mean everything from Gaff rig to Marconi to Wishbone – and seems to be used for “sloop”. Although sometimes “Leg O’ Mutton” is used as well. The leg O’ Mutton confuses me as some boats – even ones right next to each other in the record – will say J&M and in the notes ‘Marconi” and others “Leg O Mutton” and also Marconi…See #984-991 as examples. Different person entering? Why the differentiation?
2. The first production Wishbone rig was Silver Heels # 1204 – Correct? (I wouldn’t be surprised if there are some cat yawls, or dinghy’s earlier with this rig, but I don’t see anything specified in the record as such).
3. 901 the first Marconi 12 – Correct?
4. 12 40 was the first 12 ˝ with the wishbone rig – Correct?
5. 1166 – A FI 31 – is listed as a “Special Rig” – anyone know what was “Special”?
6. 1203 – Is a cat yawl/ketch – although it has multiple rig locations/Rigs - the museum owns – I assume an experimental craft as it has a special plate and this multiple rig locations? In the record is says “General Utility Class First Boat”. Was this a prototype for a new class? Which one?
Re: Questions....
« Reply #1 on: August 10, 2010, 05:51:33 PM »
1.  J&M stands for "Jib & Main".  I agree ... it seems to be used as an alternative to "sloop".  "Leg-O-Mutton" is an alternative to "Marconi".  I think these terms were used more-or-less interchangeably.
2. Correct as far as I know.
3.  Ditto.
4.  Ditto.
5.  The record has a note about the special rig, but I don't know what was special about it.
6.  This boat is on display in the Hall Of Boats.  Halsey owned it for a few years and then donated it to the Museum.  It is set up to be able to use 4 different rig locations.  It was built for Paul Hammond, an HMCo regular.  It was probably experimental.
