Author Topic: For SALE - 1974 Herreshoff Harbor Pilot 18 - Completely Restored  (Read 35671 times)
« on: September 05, 2011, 06:27:05 PM »
1974 - Herreshoff Harbor Pilot Launch - A well built and well-found motor vessel ideal for daily endeavors and weekend pleasures. Constructed by skilled craftsmen, modern hand laid fiberglass materials, teak bright work with bronze hardware and navigation lights.
Built at the renowned Nowak & Williams yard in Bristol, Rhode Island, this classic Herreshoff is offered for sale.
  It has a lifting Boom & Mast for Lobster or Crab pots hauling . Inboard diesel (Upgraded Engine Pkg.) - Westerbeke - 4 cyl. 30 hp with a Heat Exchanger unit .
 Calling all Purists. Hull # 63 is for sale. Meticulously Restored to Original, back to era of 1974. she will cruise @ 8 knots. Under 350 hours
.All new wiring including engine harness ,many ,many new parts .... Complete Restorartion of entire vessel. Custom Rebuilt 19 ft. Dual Axle Trailer!
Herreshoff - designed SIX Models from this Cat Hull ! The Pilot is one of the Rare ones !
 Price just Reduced from $29000.00 , $25000.00, $21,500 , $19,500 down to $18,995 ...
Recent improvements listed below ::
-New restored fuel tank (2011)
-New red gel coat on hull (2010)
-Rebuilt starter motor (2010)
-Rebuilt alternator unit (2010)
 -Rebuilt Westerbeke 30 hp diesel motor (2010)
-Rebuilt outboard rudder & bronze hardware (2010)
-Replaced rear main transmission seal & pressure lines (2009) >coupled to direct shaft
-Stripped bottom paint to gel coat then Barrier coat & bottom paint (2010)
-New cockpit cushions and instrument gauges (2010)
-New fan vent unit in cabin (2010)
 -New heavy duty blower unit to cool diesel motor (2010)
-Replaced windows in pilot house & vanished trim (2010)
-Restored teak rails and trim (2010)
-Painted decks and cockpit (2010)
-All new wring of total boat including engine harness (2010)
-Rebuilt custom 19 ft tilt galvanized dual axle trailer including NEW> wiring/lights, air bellow shocks,tires & wheels,etc,etc for long hauls (2011)
-Polished all bronze hardware (2010)
-Recondition bronze prop (2010)
-New engine cables (2010)
-New hand rails on cabin top (2010)
-New metal air cleaner/filter unit for motor (2010)
-New fuse circuit panel (2010)
-Purchase bronze port hole unit to see through cabin (2010)
-New ignition key & kill button unit (2010)
 -New bilge pump & float switch (2010)
 -Add hours & hours of restoration work done on this pilot …
« Last Edit: April 07, 2012, 11:56:12 PM by Cardinal Joe »
Re: For SALE - 1974 Herreshoff Harbor Pilot 18 - Completely Restored
« Reply #1 on: September 05, 2011, 06:31:20 PM »
Vessel is of full fiberglass construction with full keel for stability and prop/rudder protection for shallow water cruising. A deep keel protects the prop/rudder and provides stability.  Unlike electric boats, she is well suited for offshore cruising and/or fishing.
Additional Specs, Equipment and Information:
Specs
Builder: Nowak & Williams
Designer: L.Francis Herreshoff
Hull Shape: Displacement
Dimensions
LOA: 18 ft 2 in
Beam: 8 ft 0 in
LWL: 17 ft 10 in
Minimum Draft: 1 ft 10 in
Displacement: 2200 lbs Dry Load
Engines
Engine Brand: Westerbeke
Engine(s) Total Power: 30 HP
Engine Model: 30 hp Diesel
Engine Type: Inboard
Drive Type: Direct Drive
Propeller: 3 blade propeller
Cruising Speed: 7 knots
Maximum Speed: 12 knots
Year Built: 1974
Engine Hours: 350
Tanks
Fuel Tanks: 1 (18 Gallons)
Accommodations
Number of single berths: 1
Number of cabins: 1
Number of heads: 1
Seating Capacity: 6
Rigging
Steering wheel
Spinnaker pole
Inside Equipment
Electric bilge pump
Chemical head
Electrical Equipment
Shore power inlet
Electrical Circuit: 110V
Outside Equipment/Extras
Cockpit cushions
Covers
Mainsail cover
Additional Equipment
Road trailer
mkelleher
« Reply #2 on: November 23, 2011, 04:13:02 AM »
Cardinal Joe;
Just had accepted bid for Sky King.  I have been more of a cat boat sailor but now have a pilot boat.  Could I contact you from time to time with questions.  I won't over do it.
Mark Kelleher
« Reply #3 on: November 23, 2011, 03:15:57 PM »
SURE  .... "Congradulations"!!!!!!! and Welcome Aboard ..... - my cell # 215 416 5276 or jcannavo@gmail.com ..... Anytime   :)
Start posting up on the herreshoff 18 forum - i.e. the new home port of your Pilot and any plans for her ...... and lot & lot of pic's of ur pilot .....   Thanks  Cardinal Joe
« Last Edit: November 23, 2011, 03:32:59 PM by Cardinal Joe »
« Reply #4 on: November 26, 2011, 03:35:19 PM »
My Completely Restored 1974 Herreshoff Harbor Pilot - Hull # 63 .... Has been REDUCED in price from $29,000.00 to $25,000.00 an now down to $21,500.00.......
This is a " Turn Key " Pilot , that needs " Nothing " , but a new owner , who will enjoy hours of good times on the water , watching boaters turn their heads to look at this Master Piece of history cruising by as she did back in 1974 ...... This Pilot has " EYES " .  Cardinal Joe
« Reply #5 on: December 09, 2011, 04:12:44 PM »
Back up on eBay , price has been Reduced ...... Nice XMAS Gift !
« Reply #6 on: December 15, 2011, 03:32:39 AM »
 I have decided to take my Herreshoff Harbor Pilot " Off the Market " until further notice !  ;)
jjreid2693
« Reply #7 on: December 18, 2011, 10:40:50 PM »
Cardinal Joe, Why didn't you post a pictures?  Better yet, post lots of them so "buyers" can feast their eyes.
James Reid
« Reply #8 on: December 19, 2011, 02:33:41 AM »
   One of the "NICEST" Herreshoff Harbor Pilot ......
SeaTurtle
« Reply #9 on: December 19, 2011, 03:02:18 AM »
Joe, I have followed your boat on Ebay. I am not ready to buy but maybe in the spring!
« Reply #10 on: December 19, 2011, 03:31:26 AM »
Sounds Good ! Where is your port of call ?
« Reply #11 on: February 17, 2012, 04:30:50 AM »
My Completely Restored 1974 Herreshoff Harbor Pilot - Hull # 63 .... Has been REDUCED in price from $29,000.00 to $25,000.00 an now down to $21,500.00....... Down to $19,995.00 NOW $18,995.00
« Last Edit: February 24, 2012, 05:02:15 AM by Cardinal Joe »
Irv Mac Dowell
« Reply #12 on: October 22, 2014, 05:25:46 PM »
Hi Joe,
We met in Cape May looking at a Pilot there more than a year ago.  I'm still looking around, and I wondered whether the folks who bought your lovely Pilot might be looking to sell her.  If you have any info I would much appreciate it.
Thanks.
Irv Mac Dowell
« Reply #13 on: May 06, 2015, 12:51:06 AM »
Nope , they Love " The Pug Tug " !  The Green Hull boat in Fla. with the Pop-out Front Windows is for sale .
