Author Topic: Antique Wood Sail Boat - $29500 (Crisfield, Md)  (Read 9237 times)
« on: May 12, 2010, 03:37:31 AM »
Date: 2010-04-13, 5:31PM EDT
Reply to: sale-khfzj-1690768922@craigslist.org [Errors when replying to ads?]
Restored, refastened, canvas replaced with glass cloth on deck and no fresh water leaks. We have too many boats. She is a solid bargain priced to sell. CALL 207-236-7048 - it is much more reliable than email.
Our yacht Chance was surveyed this past fall by an old salt of a marine engineer whose family founded and ran the famous Cutts and Case boatyard in Oxford, Maryland. He worked in the Nevins yard of New York City that built many of the America’s Cups boats designed by Sparkman and Stephens. He values her at $75,000 with a replacement cost of $250,000 (if you can find enough Honduran mahogany and craftsmen to cast everything custom and put her together again). We are offering her for $29,500. It's a steal of a fair price in this market in order to sell her this year.
Construction
Chance is a rare find, the Sparkman and Stephens sister ship of famed Loki and a beautiful class design written about in Yachting magazine, The Best of the Best, Famous Yachts, Loki and Loon, and other books. She is one of the only two original Loki yawls built in the United States, and she is the only one of the two remaining in the western hemisphere. Her builder, Albert Lemos, grew up in the Azores and worked in the Herreshoff yard before leading his own team of hard-working Portuguese boat builders using only adzes and hand tools in Riverside, Rhode Island. She was built to the highest standards and incredible engineering for her day including bronze diagonal hull strapping, bronze strapping of all bilge turns, and a beautiful stiff hull shape with no hog or flex. The boat, her long history, and her prominent owners are well documented in her 40 page restoration log, box of receipts totaling $45,000 and 1,350 detailed documented hours of labor over the last 10 years.
She is carvel-planked in Honduras mahogany with white oak frames, oak keel, backbone, deadwood and floor timbers. Deck is 3/4" marine plywood with epoxy Dynel. Strapping and fastenings are all Silicon bronze; trunk cabin is 5/4" mahogany, cabin roof is 1/2" plywood with epoxy Dynel, deck trim is mahogany and the cockpit has a teak sole and 1" mahogany sides. Beautiful joinerwork and trim; interior finish is oil and varnish in need of some refinishing and white primer in need of a finish coat.
Recent upgrades and restorative measures
CHANCE was professionally restored by Stefan Topolski and a team of 5 boatwrights between 1998 and 2009. The restoration is fully documented by photograph, receipt, and daily log. As part of her rebuild, CHANCE was completely refastened maintaining her beautiful heavy, custom, antique bronze fittings throughout. Hull, deck, cabin sides, interior cabinetry and ceiling, mainmast and mizzenmast were completely stripped or removed, inspected, rebuilt, borate and glycol preservative treated, cpes sealed, re-bedded, regreased, reinstalled, refastened, and then refinished. Work included all new covering boards and toerails, cabin sides, garboards and assorted planking, butt blocks and any other necessary new components. She still needs some interior refinishing, aft cabinetry around engine box, plumbing between water tanks and sinks, and wiring for navigation lights.
The hull and structure are completed and fully seaworthy with genoa track, mainsail gate, and running backstay deck fittings being replaced. The cabin interior requires some fresh varnish, a finish coat of paint, and cabinetry over the aft engine compartment which is being built now. The mizzenmast if desired requres a new gooseneck fitting and a spreader mount. There is a cosmetic crack in the lip of transom that is not structural. This original transom was reinstalled over fresh white cedar underply to maintain as much original material in the historic restoration as possible. There is cosmetic checking in the keel when dry as it was traditionally laid up green. It swells shut when wet. Epoxy and dynel on decks replace original canvas as famed sailor Rod Stephens recommended.
For a more complete listing including all equipment and conditions on board please see David Jones Yacht brokerage listing at http://www.davidjonesclassics.com/core/listing/pl_boat_detail.jsp?&units=Feet&id=2096979&lang=en&slim=broker&&hosturl=davidjones&&ywo=davidjones&
Re: Antique Wood Sail Boat - $29500 (Crisfield, Md)
« Reply #1 on: May 12, 2010, 03:40:27 AM »
Cont........
« Reply #2 on: May 13, 2010, 04:00:50 AM »
15 pic's of this 38 ft Sparkman & Stephens ......
Additional Specs, Equipment and Information:
Specs
Builder: Albert Lemos, Riverside, RI
Designer: Sparkman & Stephens
Dimensions
LOA: 38' 4"
Beam: 9' 7"
LWL: 26'
Maximum Draft: 5' 8"
Displacement: 18,000 #
Ballast: 8,000 # lead
Engines
Engine Brand: Albin
Engine(s) HP: 24
Engine Model: AD-21
Cruising Speed: 6 kts
Maximum Speed: 8 1/2 kts
Engine Hours: 320
Tanks
Fuel Tanks: 30 gal epoxy fb
