Author Topic: Pictures of the Herreshoff 18 > America and Scout models  (Read 318026 times)
Re: Pictures of the Herreshoff 18 > America and Scout models
« Reply #150 on: February 16, 2013, 04:38:17 PM »
Joe C <jcannavo@gmail.com>
Jan 29
to plawrence
  "Try - West Marine"
« Reply #151 on: February 16, 2013, 04:39:55 PM »
11:33 AM (22 hours ago)
to plawrence
Any luck obtaining what you needed at West Marine
« Reply #152 on: February 16, 2013, 04:41:51 PM »
Joseph Cannavo <jcannavo@gmail.com>
9:16 PM (12 hours ago)
to Phil
Is it a Copper tube installed in the keel of the hull ?
« Reply #153 on: February 16, 2013, 04:44:43 PM »
9:31 PM (12 hours ago)
to Phil
look at >   KING-GAGE -  boat thru-hull fittings .......
Weld In Shell for Flush Fit
Adapt Existing Fittings for Retrofit
Accommodates AcraSensor or Electronic Sensor
A variety of mounting options are provided by our selection of weld in shells, quick release fittings or adapters. These include retrofitting tanks having other original manufacturers sensor mountings. Of course, KING-GAGE® weld in shells are available installed by most leading tank manufacturers.
« Reply #154 on: February 16, 2013, 07:03:53 PM »
Look at " Jamestown Distributors " 1-800-497-0010
Moeller Drain Tubes
MOE-021003800D- 1'' X 8'' BRASS  - $14.17
MOE-021003600D- 1'' X 6'' BRASS - $12.02
Moeller Drain Tubes are designed to allow water and fluids to flow out. Use a bailer plug to fill the tube when draining is not desired and to prevent water from coming in. These drain tubes are brass and aluminum making them corrosion resistant and have a 90-degree flange.
  MOE-21002188 - 1in X 1-7/8 in Aluminum MOE-21002188D - 1in X 2 in Aluminum MOE-21002225D - 1in. X 2-1/4in. Aluminum MOE-21002300D - 1in X 3 in Aluminum MOE-021002400D - 1in X 4 in Aluminum MOE-021002600D - 1in X 6 in Aluminum MOE-021002800D - 1in X 8 in Aluminum MOE-21003188D - 1in X 1-7/8 in Brass MOE-021003300D - 1in X 3 in Brass MOE-021253300D - 1-1/4 in X 3 in Brass MOE-0210031400 - 1 in X 14 in Boston Whaler MOE-021003400D - 1in X 4 in Brass MOE-021003600D - 1in X 6 in Brass MOE-021003800D - 1in X 8 in Brass MOE-021253225D - 1.25 in X 2.25 in Brass MOE-021253388D - 1-1/4 in X 3-7/8 in Brass
1 ea and more
1 ea and more
IN STOCK - Available for pickup
« Reply #155 on: February 18, 2013, 03:35:19 AM »
Phil Lawrence
Feb 16 (1 day ago)
to me
Good Morning Joe…
Squadron Yachts used two sizes of these fittings in the Scout and they fit 5/8 and 3/4 rigid copper tubing.
They were used throughout the boat to drain the cockpit areas, corners in the seating area where water would collect and the lockers under the hatch covers.
In many situations, rigid copper would connect two or more of these fittings and a hose would connect them to a thru hull.
I checked out the King-Gage…nothing there.
Thanks for your interest,
Phil Lawrence
ProEnterpriz, Inc.
17127 Hickory Street
Spring Lake, MI 49456
plawrence@proenterpriz.com
616 850-0600 Office
616 842-2745 Fax
616 402-4300 Cell
« Reply #156 on: March 16, 2013, 03:57:23 PM »
H-18 Catboat ......
Jim Cole <jcole@commandalkon.com>
Mar 13 (3 days ago)
to me
I Hi Joe,
I just purchased an H-18 locally and will pick up the boat next week.  Very thrilled with the boat.  Needs restored, will be my retirement project when I retire.  Information on the boat is not readily available, so thought you might be able to send me in the correct direction with your knowledge:
Is any one making spare parts for the boat.  Found 1 E-mail that said that someone had purchased the molds but did not provide the new owners name.  I did locate the OEM sail maker.
Do you have any idea who may have supplied the navigation lanterns as seen on the brochure  and also one of the boats in the pictures.  Would be a really nice addition to the boat.
Any help would be greatly appreciated.
Thanks
James F. Cole
Materials Manager
Command Alkon
5168 Blazer Parkway
Dublin, Ohio 43017
Phone 614-923-5260
Fax  614-793-0608
Jcole@commandalkon.com
« Reply #157 on: March 18, 2013, 04:40:26 PM »
Mar 13 (5 days ago)
to Jim
Congratulations on your Purchase of a H-18 . Nauset Marine , MA  - was the last company to build the Pilot & American model ????  What is the VIN # of your new Pilot or American ?
« Reply #158 on: March 18, 2013, 05:34:06 PM »
Somewhere around 1976 the “America” was available in a special “Bicentennial” model. It had some extra fancy woodwork and real working oil navigation lights. Not sure if they were offered after this – but I’d bet the lanterns Mr. Cole speaks of in the catalog are these. I do not believe these are Coast Guard compliant as navigation lights any longer – so while they are neat to look at they are probably not functional - though you could electrify them easy enough. They were probably made by Den Haan's, Perko, or W&P or somesuch – probably can still find them if you search the web…
Here is a picture - Note lanterns:
« Last Edit: March 18, 2013, 05:38:05 PM by Adam »
« Reply #159 on: March 19, 2013, 04:07:13 AM »
« Reply #160 on: March 19, 2013, 04:13:31 AM »
« Reply #161 on: March 30, 2013, 12:20:56 AM »
New owner of a Herreshoff 18 has found the Registry and will be posting up pictures and a story of his launch or fisherman model, will have to see where the Console Is located !
« Reply #162 on: April 29, 2013, 05:52:42 AM »
James Reid
Apr 25 (3 days ago)
to me
Hi Joe. it's James Reid.  As you know I own the Herreshoff Scout "Freebird" pictured on the registry.  Hopefully you can help me.  I would like to get a bendable mast for both my main and mizen mast to replace the fixed ones I have.  Any suggestions?  Has this been done before?  Is it a major task?  I"ll have to do this or sell my boat.  Thanks for all your help and knowledge.  Did you ever sell your Harbor Pilot (the Red One)?
« Reply #163 on: April 29, 2013, 05:55:04 AM »
11:50 PM (2 minutes ago)
to James
Yes , I have Sold my Herreshoff Harbor Pilot it is now the " PUG TUG " an still in South Jersey !  James > I don't know if its been done on a Herreshoff Scout before , but I had a Bay Hen &  Peep Hen in the past and both of those mast folded down ...... I'm going to ask Adam on the Herreshoff Registry for help to answer that question ........
« Reply #164 on: April 29, 2013, 02:20:58 PM »
The folded mast - or Tabernacle Mast - can be done on HA's but not sure on the Scout. Marshall Marine offers to do it professionally for HA’s as it's an option on their Sanderling Catboat (the rig is pretty much interchangeable between both boats).  See:
http://www.marshallcat.com/html/tabernacle_mast1.html
I'd give them a call and see if they could do the mods.
