Author Topic: herreshoff 18'  (Read 1246719 times)
« Reply #240 on: July 21, 2010, 08:26:50 PM »
Ray - from ATLANTIS PROPELLER,INC - has tune -up my 14 X 11 Prop ! Using " Prop Scan System " this high tech. unit - Increase Efficiency , Reduces Fuel Consumption and Eliminate Propeller Induced Vibration .... And gives you a Computer Generated Report -" Free of Charge "
« Last Edit: October 10, 2011, 01:44:08 PM by Cardinal Joe »
« Reply #241 on: July 30, 2010, 12:15:45 AM »
Continue from above ....
Some Photo's of Atlantis Propeller work ....
« Last Edit: October 30, 2010, 11:34:30 PM by Cardinal Joe »
« Reply #242 on: July 30, 2010, 12:17:55 AM »
Another Sighting of a Herreshoff Harbor Pilot in " Martha's Vineyard "... Looks like a Nauset Harbor Pilot Edition ,  they built them Without the Cat Rudder ....
« Last Edit: October 10, 2011, 01:50:41 PM by Cardinal Joe »
« Reply #243 on: July 31, 2010, 01:41:26 AM »
 Westerbeke Red ? - kinda ...
Used "RUST-OLEUM" - Professional High Performance Enamel Red Paint...
« Last Edit: October 20, 2010, 04:36:54 AM by Cardinal Joe »
« Reply #244 on: July 31, 2010, 06:11:38 PM »
Adam or Steve -Lost all my foto's from posting up yesterday ????????????????  Where did they go ?????????   Still " NO " Icon .......???????
« Reply #245 on: August 01, 2010, 01:04:35 PM »
The icons are back.
The images you posted 2 days ago were submitted as attachments.  This forum can not host your images ... see the topic on posting photos.  It needs to be done the way you have done it in the past ... including a link to the image hosted elsewhere.  You will need to re-post them using the approved methodology.
In researching this, I have noticed quite a few attachments in the server directories.  I will need to go through each one and delete if necessary.  If you have other images that were attached rather than linked to, you will need to re-post them as well.
-Steve
« Last Edit: August 01, 2010, 10:13:18 PM by Steve »
« Reply #246 on: August 01, 2010, 09:05:37 PM »
 Steve - Sounds Good - Thank You ....... Joe
« Reply #247 on: August 04, 2010, 09:48:54 PM »
" Rust-oleum Hammered " for the Custom Welded Angle Iron pieces & Axles
Both Axles Bars
« Last Edit: October 20, 2010, 04:53:57 AM by Cardinal Joe »
« Reply #248 on: August 08, 2010, 09:23:01 PM »
More foto's - Another Sighting of a Herreshoff Harbor Pilot in " Martha's Vineyard "... Looks like a Nauset Harbor Pilot Edition boat to me , they built them Without the Cat Rudder ....
« Last Edit: May 09, 2015, 03:45:26 AM by Cardinal Joe »
« Reply #249 on: August 14, 2010, 06:19:56 AM »
Started to clean up the Bronze Hardware on the Pilot >>>>
« Last Edit: October 04, 2010, 02:59:23 AM by Cardinal Joe »
« Reply #250 on: August 14, 2010, 06:23:48 AM »
Cont .... from above ....
« Last Edit: May 09, 2015, 03:54:25 AM by Cardinal Joe »
« Reply #251 on: August 16, 2010, 05:50:36 PM »
Rudder refit .....
Rudder re-install with some new hardware ....
« Last Edit: May 09, 2015, 03:57:50 AM by Cardinal Joe »
« Reply #252 on: August 18, 2010, 01:21:24 AM »
Proper way of taping off area..... to be painted with a new color of non-skid on the gunnels .....
« Last Edit: October 04, 2010, 03:39:50 AM by Cardinal Joe »
« Reply #253 on: August 18, 2010, 01:28:47 AM »
Cont. from above.....
« Last Edit: October 04, 2010, 03:44:04 AM by Cardinal Joe »
« Reply #254 on: August 20, 2010, 12:08:58 AM »
 Non-Skid Paint
Had some left over non -skid deck paint from another boat ........... states " CREAM " color , but it looks YELLOW to me ,,,,, and I Don't like it at all with the dark Red hull .... this is Not going to last .....
« Last Edit: January 25, 2012, 04:36:09 AM by Cardinal Joe »
